i did not play the video but you can do a compression test,,,,yes it could be a bad lash adjuster, i had a follower fall off caused by a bad valve...and that ran just like you said your is,when mine went, it would idle fine but you couldnt drive it. well around the block but you knew something was wrong...in the end it was cheap to fix the valves vs new engine,,,at least for me in my case,GOOD LUCK
