Need Help!! Asap
  • Thread starter Thread starter 88GT4u2nv
  • Start date Start date Nov 30, 2005
88GT4u2nv
60
Wa
Nov 30, 2005
  • Nov 30, 2005
i underwent the process of replacing the t-stat today do to heater not working properly. well when i finnally got the housing off, and the new t-stat in place the bottom bolt wont thread it, i took the new stuff out and housing to see if i could thread it in at all. still nothing, i may have possibly stripped the first 2 threads of the intake manifold. if this is the case whats the easiest way to solve this prob? am i going to have to take the lower intake manifold off? i dunno, im cold dirty and without a car. thanks
crapola i ****ing hate these ****in t-stats!!!!!!!!!!!
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 30, 2005
  • Nov 30, 2005
Try (carefully) and run a tap into the threads to see if you can clean them up. Worst case, you tap it slightly larger and put a slightly larger bolt in that hole.
giddyup306
3,041
Nov 30, 2005
  • Nov 30, 2005
Run a tap or a thread chaser through the hole. If it does not fix your heater problem, use a infared temp gague, thermocouple, thermomoter or else to measure the inlet and outletl of the heater core. If they varry it is plugged. Then try and flush it. I've done so with special equipment that puts pressurized watter in. IF that don't fix it replace.
Damn Michael you beat me to it. Friggin 56K...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 30, 2005
  • Nov 30, 2005
If Michael's suggestion won't work in you case, get a Helicoil kit. The kit will come with a drill bit, oversize tap, installation tool, and helicoil inserts. The helicoil inserts are diamond shaped spring wire that effectively put new threads (same size as the old threads) in a stripped out hole. The kit cost about $15.50. See http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results for more information
Advance Auto Parts also has them, but did not show any info on sizes or kit contents. Cost is $26 for a kit
88GT4u2nv
60
Wa
Nov 30, 2005
  • Nov 30, 2005
got the bolt to thread a little sideways, with some washers, i think that might work. thanks though guys. also the temp gauge reads normal now, but the heat still isnt that warm. crapola
T
Greetings from a guy who needs help with a foxbody.
  • thefonztm
  • Mar 21, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2026
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
M
  • mnky99
  • Sep 5, 2025
mnky99
M
