  • SN95 4.6L Mustang Tech
Need help asap
  • Thread starter Thread starter Jsun3701
  • Start date Start date Dec 21, 2006
Jsun3701
124
Virginia
Dec 21, 2006
  • Dec 21, 2006
Do wheel spacers go behind the rotor Or do I have extra long studs?
Tape
Banned
Dec 21, 2006
41
Birmingham
Dec 21, 2006
  • Dec 21, 2006
get the ones that bolt to the rotor, {hub centric} no they go over the rotor, I wouldn't install them on the front, I have 25mm (1") in the back... no problems.
Jsun3701
124
Virginia
Dec 21, 2006
  • Dec 21, 2006
Thats what I have but the studs on the car stick out to far for the spacer to fit flush?
Tape
Banned
Dec 21, 2006
41
Birmingham
Dec 21, 2006
  • Dec 21, 2006
also spacers without the bolts tend to come off
Tape
Banned
Dec 21, 2006
41
Birmingham
Dec 21, 2006
  • Dec 21, 2006
the wheel will allow a little space, install the spacer with two nuts then see if the wheel will fit flush. If they will install the rest of the studs then the wheel.
Jsun3701
124
Virginia
Dec 21, 2006
  • Dec 21, 2006
I mean for the wheel to fit flush.
Jsun3701
124
Virginia
Dec 21, 2006
  • Dec 21, 2006
I dont get what ur saying
Jsun3701
124
Virginia
Dec 21, 2006
  • Dec 21, 2006
The stock studs are sticking through the spacer about 1/2 inch. So the wheel will not sit flush against the spacer. Do I need shorter studs?
Tape
Banned
Dec 21, 2006
41
Birmingham
Dec 21, 2006
  • Dec 21, 2006
neither did mine, did you try to install the wheel ?
Tape
Banned
Dec 21, 2006
41
Birmingham
Dec 21, 2006
#10
  • Dec 21, 2006
  • #10
if you have tried to mount it and it won't sit flush then YES you need shorter studs but mine extended past the spacer as well but the wheel will mount flush.
Jsun3701
124
Virginia
Dec 21, 2006
#11
  • Dec 21, 2006
  • #11
Yah, the studs are just too long. I guess I could gring a little off the stud.
Tape
Banned
Dec 21, 2006
41
Birmingham
Dec 21, 2006
#12
  • Dec 21, 2006
  • #12
install the lug nut before you grind so when done grinding, removing the lug will straighten the threads.
Mossberg
ATL, Shawty
Dec 22, 2006
#13
  • Dec 22, 2006
  • #13
Cross threading sucks.
hotpony
922
12
38
Lee County, KY
Dec 22, 2006
#14
  • Dec 22, 2006
  • #14
pictures are worth a thousand words
Rickey_Bobby
332
Sarasota, FL
Dec 22, 2006
#15
  • Dec 22, 2006
  • #15
Thy type of spacer you are using is VERY weak and WILL break unless you drive like an old lady.
Do it the right way, Buy a standard spacer (no lugs in it) and get aftermarket longer lugs in your rear axle.
I assume this is a cosmetic thing your trying to do, because there is NO performance gain from doing this.
Your $$ is best spent elseware...
Get some lowering springs.
Tape
Banned
Dec 21, 2006
41
Birmingham
Dec 22, 2006
#16
  • Dec 22, 2006
  • #16
you have it backwards! I snapped 2 sets of studs then bought the studded adapter and haven't had a problem. BUT if you have some serious HP adapters need to be steel made by a machine shop.
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
H
Electrical 2003 GT convertible battery drain
  • Huggybear56
  • May 31, 2026
SN95 4.6L Mustang Tech May 31, 2026
Bronco2fan
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
