  • SN95 4.6L Mustang Tech
Need help ASAP
  • Thread starter Thread starter scupking
  • Start date Start date Feb 3, 2007
scupking
1,186
Enfield, CT
Feb 3, 2007
  • Feb 3, 2007
Just got done installing Professional products 75mm Throttle body but couldn't figure out how to get the throttle cable in right. This is how I have it now but think this is wrong.
I don't want to break something. How should I have it set up? The car seems to be runing good but I have yet to drive it
C
califsp
22
  • Feb 3, 2007
I just did this last week with a new TB. Actually, you're almost there. There is a hole right in line with the end of the cable connector. Just gently find it and bush in the connector towards the throttle body. It just clicks in and the cable will be were it is now.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 3, 2007
  • Feb 3, 2007
Yeah, you are pretty close. There should be a hole on the bell crank just opposite the small slot where you slid the throttle cable end into.
scupking
1,186
Enfield, CT
Feb 5, 2007
  • Feb 5, 2007
Yeah it just seems really tight. I had to use vice grips to get it clicked into where it is now. I’m thinking because its cold out (0-15 degrees the past few days) the metal might have shrunk. I was afraid to clamp it down more then I did. Should I clamp it down tighter and see if it pops in place? Or should I just take it to the local garage and have them do it? I have been driving my car the past few days how it is now. I don't want my cable to break. Other then that she is running great with the new set up and I have an Xcal2 coming in wend.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 9:17 AM
keel
L
2001 cobra sequential tail lights
  • lking78
  • May 26, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 14, 2026
lking78
L
