Need help ASAP
scupking
1,186
Enfield, CT
Just got done installing Professional products 75mm Throttle body but couldn't figure out how to get the throttle cable in right. This is how I have it now but think this is wrong.
I don't want to break something. How should I have it set up? The car seems to be runing good but I have yet to drive it
I just did this last week with a new TB. Actually, you're almost there. There is a hole right in line with the end of the cable connector. Just gently find it and bush in the connector towards the throttle body. It just clicks in and the cable will be were it is now.
Yeah it just seems really tight. I had to use vice grips to get it clicked into where it is now. I’m thinking because its cold out (0-15 degrees the past few days) the metal might have shrunk. I was afraid to clamp it down more then I did. Should I clamp it down tighter and see if it pops in place? Or should I just take it to the local garage and have them do it? I have been driving my car the past few days how it is now. I don't want my cable to break. Other then that she is running great with the new set up and I have an Xcal2 coming in wend.
