NEED HELP ASAP
  • Thread starter Thread starter projectstallion
  • Start date Start date May 17, 2007
P
projectstallion
17
  • May 17, 2007
ok so now my stang (70) won't turn over it will crank but not fire had car running and driving the other day! has new carb fuel pump fuel filter plugs wires cap and rotor starter soleniod anything i am missing?! will fire on for a second on starting fluid help needs to get tagged tomorrow
hhead
280
so cal
May 17, 2007
  • May 17, 2007
check that you're getting fuel to the carb first.
Pull the line off the carb, and crank it.
Do you have gas in the tank?
BlackGMC
247
  • May 17, 2007
New Carb, hmm the floats might be stuck. Take of the air cleaner and pump the throttle and see if you see gas being squirted into the carb..
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
May 17, 2007
  • May 17, 2007
If it will run on starting but not normally, it is a fuel delivery problem: something clogged, float stuck, bad pump,etc...
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
Help needed - Cranks, no Start
  • sleeping93coupe
  • Nov 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 30, 2025
AeroCoupe
C
06 Mustang GT has fuel and spark and dossnt stay running
  • comicchicken
  • Dec 2, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Dec 5, 2025
Dino Dino Bambino
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
