ok so simple and to the point. noticed a tapping, brought the car home. i have been having issues
with my pushrods, but have now found out why i had these issues they say the car over heated and
weakend the tips. ok ill buy that, makes sense. so i pulled the valve covers took off the rocker arms
and pushrods are all fine. Finally. Took off intake to check lifters and found one of them has a flat
spot on it and im not talking about a little one i mean if i took the wheel off and set it on a table, its
flat enough that it would look like the wheel is in the table. what would cause this? I had valve
springs in the afr 165 heads adjusted for max power to my e cam, wondering if they screwed up and i
have to much spring pressure?
Also to be noted the engine has maybe 1500 miles on it everything inside is brand new. the rest
of the lifters aside from 2 of them are worn on the edges what causes this? Any help would be
greatly appreciated im at wits end with this car. thank you
