I have an 87 GT speed density im getting to install a powerdyne BD11a how do you hook the by-pass and FMU vac lines where do they go?....
Also the kit came with a 6 and 9 psi pulley what would you run with?...the car has 19lb injectors a 155 lph fuel pump and a aeromotive AFPR...
And i want to run Locked timing is that ok to do...what would you set the base intail timing at that way 20-22 degrees ??? thanks for any help..
