NEED HELP>>CAR IS RUNNING TOOO RICH
bagel77
42
I just installed a 302 h.o. motor in a 93 mustang. I am running a mass air system. Stock motor, cam, heads and pressure reg. the motor and intake came out of a running car that really didn't run rich at all. The car at idle blows out black exhaust and when you hit the gas it looks like a black smoke screen. I bypassed the egr and removed the smog system. PLEASE HELP. Any suggestions would be great.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
