I replaced almost everything in my a/c system, compressor, accumulator, liquid line with orifice tube, and clutch cycling switch. The thing is it wont take any refrigerant. The compressor stays off for awhile then cycles on for like 3 seconds then stays off for another 15 seconds. I'm guessing that there is just not enough refrigerant in there yet right? Could it have something to do with the new cycling switch? The next two things I guess I will try are putting the refrigerant in warm water and also checking the pressure. And yes I have the a/c turned to max and on cold air, and filling with refrigerant on the drivers side
