NEED HELP: CLUTCH CABLE COMING LOOSE
  • Thread starter Thread starter jp96stang
  • Start date Start date Dec 20, 2007
J
jp96stang
  • Dec 20, 2007
THE CLUTCH CABLE KEEPS COMING LOOSE OFF THE QUADRANT.
BACK GROUND: 91 VERT WAS ORIGINALLY AN AUTO. WHEN I GOT IT A TREMEC 3550 WAS IN IT. IT HAS A STEEDA QUADRANT, CABLE AND FIRE WALL ADJUSTER. THE CONVERTION AT THE FIREWALL WAS KIND OF SHOTTY AND THERE WAS ALOT OF GIVE IN THE FIREWALL. A SPOT WELD BROKE, WHILE I WAS DRIVING IN TOWN, CAUSING THE CABLE TO COME LOOSE. I FABBED A NEW, THICKER PLATE FOR THE ADJUSTER AND INSTALLED IT. I PLACED THE CABLE ON THE LAST NOTCH IN THE QUADRANT AND RAN THE ADJUSTER OUT. FIRST THE ADJUSTER HAS TO BE RUN OUT MUCH FURTHER THAN BEFORE TO GET THE CABLE TIGHT. AFTER THE ADJUSTMENT, I FOUND THAT THE CABLE LOOSENS UP EVERYTIME THE CLUTCH PEDAL IS PUSHED AND AFTER ABOUT 10 TIMES THE CABLE COMES OFF THE QUADRANT AGAIN. PLEASE HELP ME FIGURE OUT WHAT IS WRONG OR WHAT I DID WRONG. DO I NEED A NEW CABLE OR WHAT ELSE COULD IT BE?
91 HATCH
Banned
May 17, 2007
262
illinois
Dec 20, 2007
  • Dec 20, 2007
it sounds like you need the firewall adjuster that clicks when you turn it this one wont come loose like that i dont remember the company that makes them though
oh and kill the caps lock
PUNISHER RACING
1,124
FORD CITY, PA.
Dec 20, 2007
  • Dec 20, 2007
either your cable is bent to sharp and is binding up or it is frayed and hanging up in the sleeve
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Drivetrain Time to pull and lube the clutch cable
  • LX Dave
  • Dec 21, 2024
2K
Fox 5.0 Mustang Tech Jan 7, 2025
limp
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
