  • SN95 4.6L Mustang Tech
Need help deciding on Coilovers.
  • Thread starter Thread starter TrueBlue03
  • Start date Start date Jun 27, 2005
TrueBlue03
372
Bay Area, CA
Jun 27, 2005
  • Jun 27, 2005
Words can't express how F-ing pissed i am. i am so disappointed with my eibach sportlines...about a 2" drop on all 4 corners. they sit (actually sag) too low in the rear with the front actually sitting a little higher and ruined 1 of my $310 tires cuz of rubbing.
--to correct this, i ordered some Roush springs for the rear to raise it up a little cuz they claim that it only will drop about 0.75" from stock ride height and i ALSO rolled the fender lips...turns out the roush springs dropped the car almost just as much as my sportlines...it's F__ing great! all that money for nothing!! at least the tires wont rub any more but i still dont have my raked look.
anyways....i'm okay with the rear's height now that the fenders are rolled but i need to lower the front more cuz the drop is even all the way around and with myself and a passenger and my 50 lb subwoofer, it drops lower than the front and looks like crap. I WANT A RAKED STANCE.
....so im thinking about coilovers for the front but i DO NOT want to spend the money for Maximum Motorsports kits and stuff. i wanna drop the front the cheapest way possible and i found some coilovers on ebay and was wondering if they'd do the trick. links are here:
http://cgi.ebay.com/ebaymotors/ws/e...tem=7973936403&category=33582&sspagename=WD1V
http://cgi.ebay.com/ebaymotors/ws/e...tem=7967307176&category=33582&sspagename=WD1V
if anyone wants to trade springs with me, respond or PM me.
wms004
2,864
Los Angeles
Jun 27, 2005
  • Jun 27, 2005
Those kits are cheap for a reason. Go with MM. Its a stronger kit, you can choose whatever spring rate you want (i can help if you need it deciding what to go with), and you get a brand name springs (hypercoil). Also, with the MM kits you get a choice for Bilstein struts/shocks, which most kits don't offer, and you get a setable collar on the sleeve (to make sure it doesn't loose adjustment).
Wade
TrueBlue03
372
Bay Area, CA
Jun 27, 2005
  • Jun 27, 2005
Wade
Thanks. i really want to go with some MM kit, but i really dont have the money. i need it for college next year. i'm worried if i went with the kit you have that i'll have to get new struts in front as well as new MM c/c plates. i dont have that kinda money. even tho, i must say it looks like a sweet set up.
wms004
2,864
Los Angeles
Jun 27, 2005
  • Jun 27, 2005
If thats the case, just go with some H&R Race Springs all around. Those should be fine with the dampers you have.
TrueBlue03
372
Bay Area, CA
Jun 27, 2005
  • Jun 27, 2005
the problem is i want it to be low but still have a raked look. do you know how high will those sit, and if the stance be lower in front? my sub makes the rear sag a bit no matter what springs i get cuz of the weight.
V
VividDreams
200
Lebanon County, PA
Jun 27, 2005
  • Jun 27, 2005
if i remember correctly form seeing pics, the FRPP "C" Springs have that raked look you're after, atleast i thought they did. th rear its almost at stock height, maybe a lil lower, but the front rides about where your eibachs do
wms004
2,864
Los Angeles
Jun 27, 2005
  • Jun 27, 2005
These are pretty stiff springs.. unless your box and sub weigh 200 pounds your back end won't go down much more than a stock weighted GT.
Its 1.25" all around, very similar to steeda sport springs drop
TrueBlue03
372
Bay Area, CA
Jun 28, 2005
  • Jun 28, 2005
Thanks for all the info. i think i'm just going to go with some coilovers for the front to drop it more than the rear. i'm sick of going out and risking buying more springs that may or may not work. i've spent too much money already on springs that arent to my liking.
would the granatelli coilover kit work okay that i found on ebay? i know its not maximum motorsports with the highest quality struts and shocks, but wouldnt it get the job done? and also what spring rate would work the best, 200lb, 300lb or 400lb?
TrueBlue03
372
Bay Area, CA
Jun 28, 2005
  • Jun 28, 2005
anyone???? would the granatelli coilovers work and would i need anything else? what about tubular A arms?? and what spring rate?
D
Need help with suspension, wheel + tire size, 91 Fox SN95 5 Lug
  • DHatton
  • Jun 9, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2022
nickyb
A
Ride height Measurements/SVE coilover spacer
  • adam1997gipe
  • Mar 6, 2020
1996 - 2004 SN95 Mustang -General/Talk- Mar 6, 2020
adam1997gipe
A
Need Help picking a New springs and shock!
  • Blueharry
  • Apr 7, 2020
1996 - 2004 SN95 Mustang -General/Talk- Apr 7, 2020
Blueharry
SOLD SVE Mustang Coilover Kit 79-93
  • 868
  • Aug 5, 2018
  • Suspension Parts
6K
Suspension Parts Jan 21, 2019
868
Need Help Deciding What To Do With Car. Opinions Wanted.
  • fivespeedsteed
  • Mar 20, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2014
Virtual
