I will try to make this as short as possible....
Since I first built my engine, I had an odd "miss" while cruising around 2300 rpms....between 2300 and 3000. At just enough throttle to cruise, slightly speeding up....I would get this odd, slight miss. At the time I started shifting around 2000rpms and never felt the problem since.
Last week it started doing it randomly at any RPM. It won't do it if I am 1/2 throttle or more. It will just have this miss while driving...it's hard to explain. The best I can decribe it is...you know when you are in too high of a gear just rolling...and the car starts bucking? It's kind of like that, just not to that extreme. Anyway...
I am not 100% the original "miss" and the new "miss" are related. I started shifting at 2000 about 6 months ago. So it is possible the problem has always existed, and is just getting worse now. Or it could be two different issues.
Since then, I have changed coil, added MSD, dizzy, and cap. The only spark items I have not changed are the plugs and wires.
Fuel is set at 40 with the vac unplugged, 15* timing, and 24lb injectors/MAFS.
In the past week I pulled each plug, checked them and the gap. They all looked good. I did a compression test, which passed.
Today I tried to use a Star Tester and an NGS to do a cyl stepdown test. With the KOER it would not communicate with the PCM. With the KOEO, it would pull code 67, which is "car in gear, or AC on". Neither of which are true. It has always been a 5speed, so I don't think it is an issue of a closed NSS circuit.
The other issue is everytime I start the car, the idle rises and falls between 500rpms and 1000rpms....it will do it until I quickly stomp on the gas, which quickly brings the car up to 1500rpms...then it will idle fine. It does this EVERY TIME I start the car. I checked all my grounds, and they all seem to be good. I cleaned the surface of each one of them off to be sure. The idle issue also happens when my fan kicks on...and again can be fixed with a quick rev.
Now I am wondering if the PCM itself is bad, because it won't communicate with the star tester with the engine running...and maybe it is a ground issue with the PCM itself. OR....it is not communicating with the PCM because it thinks the car is in gear.
The PCM is out of a 91 GT, 5speed.
Any thoughts would help, I am next going to clean my injectors and maybe replace plugs and wires. I am trying to avoid just throwing parts at my car, I would rather actually find the problem and solve it.
Thanks.
Thanks.
