Need help Diagnosing Rattle
MATRIX4.6
123
Need help Diagnosing Rattle***update 3/8***
Recently I had the Ford Racing X pipe installed (splines into where old H was) and since then I have a rattle at 1000-1800 rpms...initially I though resonnance but it sounds like ass...metal on metal soft clanging that paces the rpms of the engine at idle. Its not real loud but I can hear it inside the car over the drone of the exhuast...after 1800 rpm its gone. It is also more prominant when I am going up hill on an inclined driveway or making uturns. Yesterday I had the car stopped on the incline of my drive way and I could hear it...so I engaged the parking break and checked it out...it sounds like something is loose like an exhuast hanger or clamp but I checked everthing and its pretty tight everywhere...I have no clue where its comming from but it is definately at the back of the car, any help before I let a dealer look at it would be great, thanks
So after taking it to the dealer I drove around with my advisor and sure enough we could both hear the clatter...I mentioned TSB 06-4-1 and he said it sounded more toward the back end of the car which does not adhere to the symtoms related to the TSB. What it ended up being and I am not sure if others have had this same issue with Stingers (FRPP or Borla) but the rear most hanger bar on the muffler points straight backward toward the rear of the car...in my case it was butting up against a piece of the frame I think there is a bolt there also. At idle when the car is cold the exhaust contracts and it does not hit the frame/bolt but after driving around the exhaust heats up and expands backward toward the rear end of the car causing this hanger bar from the muffler to bang against this frame/bolt at low vibrating rpms......10 seconds with a torch and that took care of it.:D
I had the exact same problem with my Magnaflow axleback, but the rear hanger on the passanger side muffler was contacting the metal casing around the rubber isolator on the hanger, making it clank. 10 seconds with a torch and a big set of pliers fixed it. :nice:
if i had read your post more carefully, i might have come up with the same solution. :bang: after i installed my O/R H, i had the metal to metal contact. the left muffler hanger was touching the bumper reinforcement. i loosened the connection at the H and slid the pipes forward, problem solved.
i also had a similar situation, but it was the metal gas filler tube clanking against the exhaust pipe near rear axle. bassani xover w/ hi flo cats. this seemed to happen only when car cold. as it heated up noise went away. few mins with torch and prob fixed
