  • SN95 V6 Mustang Tech
Need help disconnecting fuel lines
  • Thread starter Thread starter 69gmachine
  • Start date Start date Jan 24, 2010
69gmachine
576
Southern Maryland
Jan 24, 2010
  • Jan 24, 2010
Hello,
I'm helping my son replace a blown head gasket, and we're stuck. I was able to get one of the fuel lines off, but the other one won't budge. I bought the plastic tools that slide in around the line, and it worked on one of them, but I'm afraid to just keep pulling on it. Are there any tricks we should know about?
I'm used to carbs and V8s, so we're both newbies on the fi 3.8.
Thanks in advance for any help you can offer.
Skymarshal
572
Dallas
Jan 24, 2010
  • Jan 24, 2010
Just make sure the disconnect tool is pushed all the way in, and then try pushing the fitting together before pulling it apart. One of the spring blades inside the fitting might be up against the flange on the line and isn't releasing.
69gmachine
576
Southern Maryland
Jan 25, 2010
  • Jan 25, 2010
Thanks for the reply, but still no joy. With the tool pushed all the way in the hose prevents me from pushing the fitting together.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jan 26, 2010
  • Jan 26, 2010
Push the connector together and THEN insert the tool. You will be able to feel when the tool releases the spring. Keep pressure on the tool as you are trying to separate.
Sometime they CAN be hard to separate. The challenge is to positively verify that the tool has released the spring. If so, try twisting and pulling at the same time.
The O-rings are stuck to the inside. Be sure to replace the O-rings. Lub with clean motor oil before putting back together.
69gmachine
576
Southern Maryland
Feb 27, 2010
  • Feb 27, 2010
I just wanted to post a follow up of how I solved the problem in case anyone else encounters this.
I destroyed the plastic tool trying to force it in. Then I used a metal pick, similar to a dentist's pick and ran it all the way around the inside of the fitting between the spring and the steel line. The fuel line easily came apart after that. On close inspection, the spring had corroded to the metal fuel line.
T
Need help locating 67 dash horn wire
  • THS70
  • Nov 21, 2025
1965 - 1973 Classic Mustangs -General/Talk- Dec 5, 2025
THS70
T
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
