need help doing efi to carb swap ?S
8urSS
i have a 89 hatchback 5 speed and i reringed another motor and plan to put it in . what all do i need to swap to carb?
i have a holley red pump for fuel
msd 6al for ignition
i plan on using a distributor from a 85 roller motor from autozone
someone said u had to cahnge something in the lifter valley but i dont see what? im just asking before i do it ?
also i will have the full mass air conversion for sale if anyone interested and efi upper and lower injectors and all
also the new motor is a 92 with f 303, 1.6 roller rockers, wiend 8011 intake , 650 holley and a 125 shot of nitrous the stock 92 motor ran 13.6s with gears and exhaust in my buddys car with 120,000 miles anyone have a close combo or any predictions on what it will run car has full exhaust , fivespeed , 373 gears
thanks for any help
I went from a 4cyl to a carb 302. I just cleaned up the heads and bolted them and the intake on. I blocked off the egr on the heads and that was about it for the motor. You will have to rig a pickup for the fuel and do your own lines back there and at the motor. You will also have to run a hot wire back to the pump ..etc.
