Need Help Dont Know If My Clutch Is Going
I recently bought a sve cold air intake from latemodelrestoration and ever since I installed it my car has no power in 1st nor 2nd until I get past 3k rpm my mods that the guy I bought it from said is it has gears and a camshaft (e303) and full exhaust other than that it's stock wat could be the problem please help
Down on power isn't a clutch issue. A slipping clutch is a clutch issue.
You issue pertains to the CAI install. Check to make sure all electrical was reinstalled and connected properly, especially the MAF. Also, double check your install. Make sure nothing was accidentally in the filter and is now sucked into your MAF and blocking airflow (i've seen this before)
