Need help fast! Fixed head gaskets and now won't start
Installed new head gaskets, put car on #1 TDC, and it turns hard and uneven like its out of time, but only with the key. Turns free when I jump the engine solenoid with a screw driver. What could be wrong? Could I have gotten the valves too tight? I got it started once but it runs really rough, is missing and won't idle.
Posted via Mobile Device
Reatap dizzy. Put engine TDC on compression stroke. (pull #1 spark plug and you should feel a good bit of air blowing on your finger as you approach top ead center). once their pull dizzy and put back in with the rotor stiking number 1 spark plug wire. Like mentioned above, maybe your valves. If your heads and rockers are stock, You couldnt have overtightened them
