NEED HELP FAST! re-pinning o2 harness... thanks
OonDeanisS
902
Danbury, CT
i need to re-pin my o2 harness where the black wire loops the purple/yellow to the blue/yellow wire, but i cant figure out how to re-pin it. can someone please help me re-pin it? i am on a lift at work and i only have another half hour to get this done. sorry for the rush. thanks so much.
well, i figured it out. Take a knife and pop out the red plastic in between the pins, then look inside it. there is a little tab holding each pin in the harness, if you get the knife in there and reach the tab, you can pull the wire and pin out from the back side and re-pin it into the correct spot, just make sure you loop the correct wires and remember to re-install the red tab! this should be sticky. lots of guys say they know it can be done, but don't know how. i searched and couldn't find this info anywhere.
