Need help from a Pro.
topdowncruise he was going to use with a s-trim unit but decided to go a different set up on another car.
Pro50sc
I checked the fuel pressure I am building up to 42psi while cranking only holds pressure @ around 23psi. Still not getting any fuel to fire motor.
Any ideas?
Bernie is right. I would use a noid light to ensure you have proper injector pulsing. He outlined the power pathways correctly.
Good luck.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. There is a separate blue fuse link for the coil which can open up and rob the coil of power.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Pro50sc
Any ideas?
42 psi should start the motor provided the spark and compression are good.
What method did you use to check for quality of spark. Did you use a tester with a preset gap or just the old screwdriver method against a ground?
Have you checked any of the other cylinders to see what the plugs look like?
I know its sounds strang but Im thinking the distributor may be the culpruit. I know he had a MSD TFI distributor on car when i first went by to look @ car & he put a stock tfi dizzy on when I went back to close the deal. maybe there is a problem with distributor not working properly but working when I am testing for spark etc? Although that wouldnt explain why Im not getting any fuel into cylinder?? Im getting pissed... I need to take a breather & come back fresh tomorrow & rethink the whole deal.
Im not going to get any sleep until I get this worked out...
bill
I don't think both injector wires should be hot whether the harness is connected to the injector or not. One of the wires is VPWR which supplies the power and the other is a grounding wire from the computer, so both shouldn't show voltage - if I understand this correctly. You should only be getting voltage from the red wire.
Really, it might be messy, but you could pull one of the injectors out of the lower intake, connect it to the harness, but it inside a cup and crank the car...have a towel or something to clean up any fuel and wear safety glasses, etc. JRichker has a similar thing involving a paper cup and water w/ compressed air, I believe.
That was what I was getting at earlier. I would use a noid light to see if the injector harnesses are pulsing.
Good luck.
I may be wrong but the way I understand it the computer grounds out injector so both would read hot with test light with KOEO. I didnt use multimeter just test light on injector to be sure it was getting signal.
Bill
Go back to the checklist and start with the fuel section, #3. It is designed to work through the problem areas, one at a time. That way you don't miss any important clues that will show you what is really wrong. Jumping from this theory to that theory leaves lots of places for things to fall through between the cracks.
If you get stumped , post the step that isn't working or needs more explanation. I will try to help.
the computer grounds out the injectors, that's right. Ground isn't hot, hot is voltage.
I can't remember how a test light works (how it connects to the wires), so if you could use some aligator clips and attach on to each prong in the injector harness (ground side to ground, power to power, obviously) and see if the light goes on when you crank.
Both should never have power, only the VPWR wire should have power, the other pulsates ground when the car is cranking/running.
And yeah, I would recommend just going back to the section of the No Start Checklist that JRichker is speaking of. The man knows his stuff and that list catches most problems.
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles...-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
I got good spark 30,000 according to spark/gap checker.
I got 42psi while cranking engine, holds pressure @ 23psi when not cranking.
I got the engine wanting to run with the carb cleaner sprayed in it but cuts off as soon as the cleaner gets used up.
I got power to both injector wires with KOEO. w/ circuit tester.
I pulled #1 plug & no smell of fuel on plug or in chamber?
I am positive I got the timing dead on. IE it runs with the carb cleaner in intake.
I am scratching my head on this one, I'm usually giving advice on whats wrong with people's rides & I'm literally stumped on this problem.
My next move is going to be install my MSD 6AL box & Pro billet dist. off my dragcar & see if it will run with it installed. For some reason Im thinkingh this TFI or dizzy is messed up giving me false reading.
bill
I would hold off on adding more parts - you are relatively sure you have spark now, so why introduce more variables?
I would be going over the fuel side again (no fuel on plugs, runs on ether, etc - those are clues to me). Look for breaks in the wiring on each injector. Those wires can get brittle.
Also, check your sensory input to make sure you dont have something pegged from bad wiring or a bad sensor. FOr example, if the TPS shows WOT on the return voltage, the injector pulsing is cut (no spray).
Good luck - and JR had very good advice and I would follow his list and his subsequent posts. I did not mean to echo anything he posted or step on toes. I started off posting about the addition of variables and started rambling. :bang:
yeah
is the distributor dropped in properly... #1 cylinder up at tdc ( top dead center) on the compression stroke...( meaning both intake and exhaust valves closed.. and the distributor dropped in with the rotor facing straight back to the firewall.. which normally is #1 on the distributor cap... then check your firing order... if you have an ho motor then the firing order should be 13726548 if you have a none ho motor the firing order would be 15426378 these should be in the counter clock wise direction. At that point if this is all ok and checked properly ... you should then check to see if the orange wire on the injector harness is properly grounded... this is a single long wire coming off the injector harness with a big eye on it. that should be grounded to the back of the cylinder head... if all this is well and good then go to the next check...
to see if your distributor is working the fuel pump. turn the key on engine off koeo... and turn the distributor back and forth... if the fuel pump primes then your pip in the distributor is fine and working correctly... other then that.. you may need a new ecu... also check your tps voltage.. should be at .98 with the throttle closed.. off gas pedal... if the tps is bad and showing wot ( wide open throttle it will not start.... there are very knowledgable people on this site... listen to them they help out alot...
get back to us...
I am in the process of double checking everything.And I am checking all the ground wires including the ECM grounds, I borrowed a msd dist & ignition box from a friend if all else fails I will hook it up & see what happens AFter I eliminate everything else. I really do feel there is a wealth of knowledge on this website. I am know I can give some input on certian problems as I have faced many on rebuilding stangs from 1968 til now. The carb stuff is pretty straight forward this EFI is new to me & I'm really looking forward to learning all I can, just wish it coulda ben on another car instead of my first modified EFI.
I'll keep you posted later tonight I'll post new info & hopefully a cure.
bill
Ok here is a little update for whats its worth. I traced the wires on back on motor & the steel engine to firewall ground wasn't hooked up no big deal, bolted it to head. And I found the orange wire on passenger side not hooked to ground either,thought I may have found problem there but even with it hooked up no change in problem. Still got fire & in time but no fuel is getting past injectors, I ordered a noid light kit & a power probe test kit today for checking injector pulse hopefully there is where the problem is but I did get voltage on red wire with key on. OH IM SO TIRED>>>>
You'll get 12v on both sides of the injector. The "ground" side (EEC side) of the injector floats at battery voltage until the EEC electronic switch fires and grounds that side of the injector, so be sure the EEC ground is good.
