Need help from a Pro.
Tmoss isn't thew orange wire on back of wiring harness the EEC ground wire? I thought it was anyway, I have a noid light kit I plan to use that later tonight to check wiring harness to each injector, the light should flash if workling properly correct?
Bill
Ok I got my noid light set in today, check the #1 & #5 injector harness both of those are flashing as they are working or should be working, I dont know if I should pull all the injectors & have them tested somewhere or what. Can you bench test an injector?
Bill
Have you checked for fuel volume. You can have good pressure but not enough volume. Somethin' to look into. Maybe your regulator is bad and the fuel is just going back into the tank. You would have to block off the return line in order to find out.
Or if you have a relief valve on the pressure gauge you bought you could do it that way. Run a hose from the relief valve into a 12 or 16oz juice bottle. Open the valve and have someone crank the engine. The bottle should fill up in a matter of seconds.
Pro50sc
I did see a pretty good flow when I checked the fuel pressure I held the relief valve open to see if maybe line was locked with air or not suppling any volume & seems to be pumping good flow. I am goint to pull the upper intake off, check each individual injector to see any signs of them being fouled up, they are ford 36# units & look fairly new, but I didnt install them so maybe aome or all are bad.
Bill
Ok I am almost positive it has to be the injectors now I am removing them all has anyone ever heard of all the injectors being bad at same time? I heard of maybe 1 or 2 not firing but never all 8 bad at once.. ??
Bill
I am pulling top end of motor back down today, I was reading a few articles online on how if injectors are stored in open air they actually can rust & corrode inside causing the pintles to stick & there isnt really any repair to them if the pintles get damaged as they will leak pass the seal with pintle corroded even if cleaned. Also I'd like to know if anyone in forum has ever sent their injectors out for clean,reseal & flow testing? I don't have anyone local to do it but saw several hi-perf. shopd in Ca that offer a low $$$ service for such service assuming yours are good.
Bill
Ok for all those people following my saga on this no start no fuel problem, I have good news. "It's alive" i pulled the induction back off, pulled the fuel rail & injectors,valve covers off,double checked the timing making sure both valves were closed on TDC, all ok there, cleaned injectors with carb & choke cleaner,sprayed off immediately with shop air, ran a OHMS test all were 14.3- 14.4 for those whom may want to know for their own info,installed new upper intake gasket just to be safe, installed rest of induction. First test on restart was a same as before after adjusting dizzy a few degree's it let out a huge book thru exhaust. I said to myself allright I fianlly got fuel to motor. After 2 or 3 restarts & adjusting dizzy started & ran on its own. Man does it sound so good. That TF stage 2 cam has a giant lobe separation. I'm afraid it may be idling to low... But its at least running I am so glad to get this problem resolved. I wish I could say this or that was the problem but I am stumped I never found anything wrong with anything I disassembled. Maybe the injectors just needed a good bath & blowing shop air thru them helped?? Thanks to all those with advice & helpful hints to check out.
Bill
