I have an 87 Gt, Have my ECM already out of a 93 gt going to buy new throttle body, EGR spacer, mass air meter, Injectors, and a new fuel pump.
in a few months will probably stroke my engine. was wondering what the best combo of sizes and injector size would be. I know I might as well get the 255lph fuel pump, Was thinking going 70mm all the way with the mass air assembly, spacer and throttle body, with 30 lbs injectors. Will this still keep good drivability on my stock motor before I can put the stroker in, and if so will it have a fuel/air starvation when I put a higher compression 347 in there?
All info would be much appreciated. Also will my stock fuel lines and regulator do the job?
