I found this part lying on the floor, very greasy (clean now) lying in the vicinity of where my steering column was setting, but then has been moved.
The part has to fit somewhere just under the turn signal switch assembly, but I am not certain.
It fits tightly around the steering shaft itself so I have to be close as to where it goes. The OD of the part is about 15/16".
Also if it is a steering column bearing or sleeve, should it be split?
Thanks up front!
sparx
Thanks up front!
sparx
