Fox Need help identifying these connections.
James V
5 Year Member
Feb 26, 2017
409
144
63
Connecticut
Found these 2 plugs in engine bay, driver side. What are they for? I have a 93 lx coupe.
Also noticed there is a gasket? On the transmission, but it doesn't look connected, is this normal?
The plugs in your hand are the diagnostic plugs. They don't connect to anything under the hood. They are for reading engine trouble codes.
That " gasket " isn't a gasket... it's more of a spacer. It's called the engine block plate. It should have small bolts holding it to the transmission. The bolts aren't really needed. The big bolts that hold the engine and trans together sandwich that plate.
Thank you! So that gap that I have between the plate and trans is normal? It's not flush to trans
