Need help NO start Hot condition
  • Thread starter Thread starter 88GTMustang
  • Start date Start date Apr 18, 2006
88GTMustang
247
LA california
Apr 18, 2006
  • Apr 18, 2006
im fed up with my car, im about to junk it if i dont figure this out! i drive the car and shut it off after its warmed up and it will not start back up. i have to wait at least an hour then it will fire right up. When i try to start it up once in a while it will start if the gas pedal is held down halfway. The car also cranks over fine when hot. this is what i have done so far.
-swapped known good parts such as
coil
distributer
fuel rail, injectors, regulator
mafs
wire harness for injectors, temp sensors, egr tps to salt n pepper plugs
plugs wires
-bought new
ECT sensor
Tps sensor
TFI module
nothing has helped it!
Its a gt40p motor with Ecam if that matters.
Please help
N
Notchbackdrew
44
  • Apr 18, 2006
some cars have difficulty starting when there is hot hot hot HOT fuel left over in the cylinder. On my SDS tuning device, on startup when the engine is very hot I have my injectors spray a lot more fuel in the cylinder then normal, to wash out the boiling fuel.
Im not sure how you would correct this problem, but for me its easy. Good Luck in your search, free bump!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 19, 2006
  • Apr 19, 2006
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground.
. See the above graphic for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 19, 2006
  • Apr 19, 2006
There's alot of us with this problem... and it's random right? If I find the problem with my car I'm doing a #$%# write up and posting it all over the internet
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
  • dan50
  • Jul 18, 2026
dan50
