- Jan 23, 2002
- 97
- 0
- 6
Hi All,
Need some help here. My car is overheating...but can't figure out what is causing it... I drove it around..not hard...and the car temperature remained around the "N" in Normal.... When I started putting load on the car and accelerating harder, the temperature started rising... it hit the "L" and I pulled over..the fan was not on at all....if I turn on the A/C...the low speed fan turned on... I turned the car off...and let it sit a while....when I turned the car back on...the temperature gauge was at "R", but still no fan....
I changed the thermostat, radiator cap, and flushed the coolant...the water pump seems to be flowing..and the coolant was clear when I drained it...
Any suggestions?
Any suggestions?
