  • 2005 - 2009 Specific Tech
Need help P0103 code
  • Thread starter Thread starter Dewy4PrezII
  • Start date Start date Mar 4, 2012
D
Dewy4PrezII
  • Mar 4, 2012
Hey all, I am new here and I need a little help. Thursday my mostly unmodified (steeda CAI, Predator tuner, axle back exhaust) went into limp home mode immediately after starting it after work. I got home fine and then checked it out. I used the predator to check the code and got a P0103, MAF High. One of the clamps on the induction was loose so I pulled it all off, cleaned the MAF and reinstalled it tight as a drum. No change. I then uninstalled the tune and reinstalled it. Still no change. I suspect the MAF is fried so I have one coming tomorrow. My question is does the car generally go into limp home mode for a bad MAF? Are there any other things besides the MAF or the PCM that can cause a P0103 code?
D4P
bigb427
128
Las Vegas, NV
Mar 5, 2012
  • Mar 5, 2012
By far the most common cause for MAF related codes is the MAF sensor being disconnected, or not completely connected and latched. The best way to diagnose this concern is to use a capable scan tool and monitor the MAF sensor voltage with the engine idling. The voltage should be aprox. 0.6 to 1.0volts with the engine warm at idle. Wiggle the MAF sensor wiring (esp. at the connector) and tap on the sensor to see if the voltage stays in that range and remains steady. If you don't have a scan tool that will let you look at the MAF output you can listen for noticeable changes in RPM while wiggling the wiring and tapping on the sensor. If you find the voltage to be out of spec or the RPM changes you have found the problem. If you found a fluctuation when wiggling the wiring, you will need to change the wire harness connector.
Since you bought a new MAF sensor you can swap the sensor out and see if that corrects the concern, but MAF sensors rarely completely fail. With the concern present you should notice very poor throttle response. If the sensor itself was the problem, replacing it should result in normal throttle response.
BlackRod
55
Southern California
Apr 7, 2012
  • Apr 7, 2012
I think I got that code once (At least I think it was that code)...This was 4 years ago...check your throttle body...mine was really dirty from the CAI. That might help your problem.
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
07 v6 4.0 wiring issue .In desperate need of help.
  • Staycstang
  • Sep 19, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Sep 19, 2025
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
