Need Help Please.....im going crazy!!
  • Thread starter Thread starter MY 85 GT
  • Start date Start date Jul 28, 2008
  • 3
  • 4
1 of 4 Next Last
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
  • Jul 28, 2008
Im giving up really quick on owning this car...I can NOT find out whats wrong with it...I bought a brand new 600 cfm edelbrock...I installed a new Dura spark module today i put new plugs in...And after about 20 minutes of drive time...AGAIN bucking ..missing ....barely can drive it...what can be wrong...and now i have a ticking sound in the exhaust which i have never had before...I really dont know what else to check...timing is fine...new fuel pump ...brand new not even 1 hr old carb,,,did the same excat thing with the older plugs and carb on it....I tried taking off in 3rd to put a load on it and forget wont even budge just missies bucks...does everything but move i have autolite 25's gapped at .044 and i have an accel coil and accel wires...when i pulled the other plugs out they looked fine they all looked the same not full of fyel or carbon nothing....what can be wrong????? what am i missing.....
87coupe50
105
WAYNESBORO, PA
Jul 28, 2008
  • Jul 28, 2008
Fuel filter?? have you tried the .050 gap on the plugs as the book says?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 28, 2008
  • Jul 28, 2008
Check your firing order on the distributor...make absolutely sure you have the HO firing order on it (i'm assuming this is a factor 4 barrel carb car right?).
Have you made any adjustments on the carb? I hinted in the other thread that i'm not a fan of Edelcrock carbs but a 600 should be pretty close to where it needs to be if the rest of the car is close to stock. Are you sure there's no vacuum leaks? What about the smog equipment? Stock intake? If so did you block the EGR passage at the top of the intake?
93 LX
3,081
Norwalk, CA.
Jul 28, 2008
  • Jul 28, 2008
Whats your Fuel pressure when its running bad? I had a carter HP pump and it was bad from the box. Took it back got a replacement and its been fine ever since. Check your spark too. It could be the hall sensor in the distributor. Mine went bad in my 82 and it ran bad all the time.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 28, 2008
  • Jul 28, 2008
This doesn’t prove that the block is a HO block. Some trucks evidently use a HO firing order
with a low lift cam. However, it will definitely prove that a block can’t be HO because the firing order is wrong.
Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
  • Jul 28, 2008
The fuel filter...i have is clear..looks clean...Im thinking if i had a bad fuel filter the pressure would be low..I have 5.5-6 psi at all times....
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 28, 2008
  • Jul 28, 2008
I don't think plug gap would cause the problems you're describing. That to me sounds like the timing is out, the firing order is wrong, or like mentioned above either the distributor is going bad or possibly the Duraspark but that would be the last thing i would check. Check the firing order first.
Do you by chance have anyone local that you could borrow their distributor and see if that solves the problem? Otherwise i believe a rebuilt distributor from the parts store is only about $40.
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
  • Jul 28, 2008
The car fine...since the day i bought it...the fifring order has never been changed...The car is a factory 5.0 as far as i know...The carb is brand new...I adjust the idle/air fuel mixture screws with a vac gauge...got the highest level on the gauge....right around 18.5-19....The car is stock except for the long tubes, H-pipe no cats....Mac cat back....i dont think there any any vac leaks i have an air fuel gauge i think it would show lean when im driving which it doesnt....All the smog equipment is gone....eveything...I have a smog pump elimating pulley on the car....stock intake....EGR valve was on my spacer thats gone too i put a phenolic spacer on now...do you think it has a leak under the spacer???
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
  • Jul 28, 2008
The fuel pressure is about 5.5-6 psi at all times....Thats the only thing i havent changed the hall sensor....will the car run if thats bad? and how hard are they to replace???
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
#10
  • Jul 28, 2008
  • #10
I replaced the duraspark today its new...the car some what runs ok until it gets hot like after a 20 minute ride then it goes down hill from there....I think the firing order is fine the car starts right up idles perfect but as soon as i engage the clutch put a load on it it bucks misses.....so on and so on...How do i know what gear i have on the Dist..i see it says steel gear or cast gear....how do i know which one i have....and if its the Dizzy..would it do this?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jul 28, 2008
#11
  • Jul 28, 2008
  • #11
Is it overheating? I've seen cars with the thermostat stuck closed act like that too.
The type of gear is just going to change the wear characteristics....the roller cams use a steel gear and i believe the older style used bronze...but that shouldn't cause running issues.
As for the fuel pressure....where is your gauge? Can you see it while you're driving? I'm working on a car right now that has 6psi at idle but is starving for fuel when you go to drive it. It starts and runs fine and revs fine but under load it starts bucking like crazy.
What about the intake stuff i mentioned earlier? Is it a stock intake? Did you block the EGR passage on the top where the stock EGR spacer/plate used to go?
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
#12
  • Jul 28, 2008
  • #12
The fuel gauge is right on my cowl its an autometer.....i have it in my sight at all times thats why i put it there i thought that was my problem fuel pressure is fine always stays at 5.5-6 even when its floored it might drop down to 5 psi the lowest....
YES...i have a stock intake the EGR valve used to be on a spacer plate i took that plate off and in its place i put an 1 inch phenoilc spacer....i didnt block anything all i used was a gasket then the spacer another gasket and the carb....What should i have blocked off???? I'll take pictures for you hold on....lol
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
#13
  • Jul 28, 2008
  • #13
heres some pictures maybe this might help....
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
#14
  • Jul 28, 2008
  • #14
I checked the firing order its fine and its the HO firing order....
R
Rick James
172
burlington new jersey
Jul 28, 2008
#15
  • Jul 28, 2008
  • #15
You said timing is fine?whats the base setting at?whats it advance to and at what rpm is it all in by?.Does it happen at light load or heavy load?can you disconnect the secondaries on the carb?I assume you have vacuam secondaries?Dont give up on a nice stang it will be worth it once you get the bugs worked out
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
#16
  • Jul 28, 2008
  • #16
I have the intial timing set at 12 degress...total at 3000 is about 34 degress ...The stumble occurs under any type of acceleration light, heavy, normal, going up a hill down a hill....lol....It did the same excat thing with the 650 cfm carb i installed a new duraspark module did the same thing changed the plugs did the same thing....Alwsy seems to do it after like 15-20 mintues...I know now i have nothing blocking te EGR passege under the space besides a gasket thats it but if that was the problem why not when the car is cold only after it seems to warm up does this problem occur...I was so happy when i bloted the new carb on with the new plugs today started WOW what a difference is was smooth powerful...then after about 15 or so mintues it all went down the crapper ran the same way as id di yesterday and i replaced the carb.plugs,module....I dont know where else to check.....
R
Rick James
172
Jul 28, 2008
#17
  • Jul 28, 2008
  • #17
How old are those plug wires?Are they the Accel ones?If they are,every set i tried SUCKED and caused probs for me.
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
#18
  • Jul 28, 2008
  • #18
Yes there accel...there about 3-4 months old....
R
Rick James
172
Jul 28, 2008
#19
  • Jul 28, 2008
  • #19
Did the prob start around that time or before?
MY 85 GT
1,852
208
104
New Jersey
Jul 28, 2008
#20
  • Jul 28, 2008
  • #20
Well this problem started about a few weeks ago it has been getting progressively worse day by day ..I had these wires on the car wit the stock manifolds and exhaust and when i had the 1405 600 cfm edelbrock on the car it seemed to run fine..I did have a slight stumble back then but i found it was timing that caused that...Now it just runs like crap after the car has been running for 15-20 minutes....
  • 3
  • 4
1 of 4 Next Last
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
  • brandyn200
  • Jun 20, 2026
AeroCoupe
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
