Need Help Please.....im going crazy!!
Well for starters, i'm not 100% sure but i think these are open vacuum ports....at any rate i always plugged them:
Also about the EGR passage on the top of the intake, i can't really see it so i can't really tell if your spacer is covering it properly or not. All i can say about that is maybe take the carb off and double check just by looking all around the spacer to make sure that hole is covered.
I've also seen the infamous "one tooth off" deal with distributors where you've almost got #1 all the way up but not quite and you drop the distributor down but it's a tooth off either way and that'll really screw your timing up.
It's hard to say without being there....and i'm actually dealing with the same hickups on a buddy's car right now. We're gonna swap in a different distributor and ignition and see if that helps and then swap the carb and see if that changes anything.
I checked the Vac things there not leaking anything...i wish they were...so that was the problem...The gasket and spacer seem to cover that EGR valve passage i checked it today....Also i was having a fule problem to much of it blow past my needle and seat fixed that with a fuel regulator...But the car after 15-20 mintues runs bad idles great runs bad,...I was told to take the Coil off the intake and re-locate it to the fender were it will be cooler...On the intake its very hot there i bought a new coil anyways...new cap..new rotor..new coil wire im going to try that stuff tomorrow and see what happens....If it still runs like crap it goes the the shop and hopefull they can fix it....The last thing would be the dizzy i guess...or maybe igniton wires there accell and about 3-4 months old but maybe there breaking down for the heat under th hood now with the headers....Oh by the way the car ran great before i had the headers and exhaust stuff done and i had all the polution stuff taken out maybe i should have left it alone....it hasnt run rught since i got it back well it did but it went down hill quick once that 1st like stumble happened....
I noticed that emission tube that connects the back of the heads is still on...do you have that plugged? I don't think it would cause the problems you're having, but it would be a big exhaust leak.
Did you have the edelcrock carb on before it started running bad?
Yea what the hell is that?cap the vac lines or pull it out and plug the hole.Try your tune up parts wires,cap,rotor.You say the fuel pressure is good when it happens,so we can rule out fuel system and you also replaced the carb with no change..Also make sure theres no other vacuam leaks.Just make sure your wires arent touching the headers.
I think its electrical of some sort after the car warms up like after 15-20 mins it starts going down hill fast....Wehn cold it seems to run ok really cant get it dialed in because it warms up and starts acting up quickly...Im going to try the cap,rotor,new coil re-loctaed and new coil wire...maybe even new ignition wires after that im done....I GIVE UP!!!!!!!!!!!!!!!!!!!!!!!!!
I don't think it's electrical if it starts up and is fine until it gets hot....THAT makes me think head gasket or a cracked head or something like that, that would only rear its head once it's warmed up and things start expanding.
Yeah i said it starts up fine and idles fine as soon as you drive it put a load on it it will stumble...buck...miss....when it gets hot it seems to only get worse...Ive had cars with bad headgaskets i dont think this is it...If it was i would be overheating...spiting water in the oil or compression into the Rad which im not....I never rule out anything but i dont think it is...maybe but i dont know....
Sounds like ignition.... could be a bad hall element inside the dizzy....
I think you might be right but im trying one last thing before i replaced the Dizzy...i have one to put in..i want to re-locate my coil to the fender mine sits on top of the intake were it is very very hot...so im going to try that ,then if that doesnt cure the problem ill do the Dizzy ..im replacing the old coil with a new one and coil wire and cap and rotor....
It depends on where the head gasket blows out at. Mine blew out between two center cylinders and didn't get into any water or oil jackets...i was just getting cross fire or whatever you wanna call it between the two cylinders. The car would idle and even drive fine until you put load on it and then it sounded like it was falling apart. I drove it 20 miles to my buddy's house to fix it. I dunno, i'm just throwing out ideas.
I think I fixed it.........I moved the old coil to the fender were the newer mustang have there coil located, when i removed the coil wire is was full of oil....mineral oil that it the coil was leaking that tells me that the coil must have overheated up by the intake....I put a new one in new coil wire and cap and rotor...took if for a 20 minute drive didnt act up i hope that was it going to take it out for a long ride in a few mins....to see how it acts..Im still going to change the Dizzy anyways it is 23 yrs old....for $60 it is the stock one tho but its better the a 23 yr old one....please wish me luck that i fixed it.....:)
Well.. Did ya!!!! :nice:
:cheers: She is up and running....never ran so good....I did the coil and re-located, to the fender...new coil wire...new cap,new rotor, I put the new 600 cfm edelbrock on...WOW this car has some punch now...Im going to fine tune it this weekend to hget the most out of it...The best part of all yesterday i was going to watch my Friend play softball..stopped at a light and a guy and his girlfriend pull up to me in some BMW 3 series coupe,,,he had his air on,hr must have shut it off he rolled the windows down and then Actually started reving the motor at me...LOL...so i reved back ...well i did a nice 3000 rpm Launch spun 1st hard hit second i was gone...He was like 3 - 4 cars back on me even while i was spinninf i was ahead of him....lol...Now i need to find this damm ticking noise i think its dirt in a lifter doesnt do it all of the time...what can i use to help that?
Nice man i'm glad you got her up and running again :cheers:
Sometimes issues can be tough and make you want to give up - glad u stuck it out and got her running again..
Honestly are you sure that "tick" isnt' a small exhaust leak? :shrug:
It could be but if it was i think it would do it all of the time this doesnt happens more when the car is fully warmed up and doesnt do it all of the time...when it does do it if i set up the gas the tick will go away thats makingme think a lifter is a little weak or dirt stuck in it....I changed the oil a week ago and it stared just recently...Now i use 15w-40 rotella diesel oil only reason i do is because it has certain additives that help lubericate..I alos put in a stp oil treatment maybe i shouldnt have done that...or maybe i should try a different weight? or use that weight no additive??? what do you think?
I knew it had to be something stupid like that. The car i'm working on turns out to need a new ignition in the column....we found that when you try to drive it the ignition shakes and the short is cutting out power to the engine's electrical system.
I'm kinda suspicious about the coil being on the intake and that being a problem....that's where the factory coil is....either way it's better on the side.
I'd suggest registering over on carbdford.com and checking out their technical links forum...they've got a lot of great how-tos that involve the factory ignition and distributor, and both can be made to be stout performers for really cheap. You can lock out the factory distributor to basically work like a mechanical advance setup and it'll give you better performance at the track (if that interests you).
:nice: Cool, and you wanted to sell it huh?Getting aggrevated is part of owning any kind of car.Believe me i at one time wanted to drive my car into a wall after i set it on fire.lol.I am going down to Englishtown probably in 2 weeks to finally make a few passes if your interested.Oh and put some 10/30 in there,i dont know why you put diesel?oil in.But congrats on getting it done.:flag:
What day you going down to E-town...I put diesel oil in because thats the only oil on the market that still has special lubricates in it ...like graphite...and something else...I worked for a company that had all Ford Trucks thats what ford themsleves even reccomend to use in there motors....Im just wondering from changing my oil if a piece of dirt is in a lifter or a lifter didnt pump up all the way....I always prime the motor 1st before starting it after an oil change...i disconnect the coil and crank it to the oil pressure is reading....
Its not there all of the time tho....
