Need Help Please.....im going crazy!!
Well,i personally think its ignition related,could only be wires,coil or distributor.You already ruled out the carb,if it was an internal mechanical prob with the engine it woud be a consistant problem weather it was cold or hot.Since its carbd theres alot less and cheaper parts that can go wrong.Figure...if its the original dist. and coil they are what 23 yrs old?WOW do i feel old.
Well the coil is new too...its also an accel coil..new duraspark module..new carb..new plugs...timing is fine.Firing order is fine...the only thing im thinking is the Dizzy well the hall effect maybe...but why when hot not cold...and i thought when they went bad they went bad the car wouldnt run? Should i buy a rebuilt dist and try that? how hard are they to install? i did alot of small block chevy dizzys...never a ford i heard there hard to do because of the oil pump shaft or something?
I honestly have never had to change one yet on a ford,but i would assume as long as you are carefull pulling it out and made sure the oil pump shaft doesnt fall into the pan you would be o.k.Maybe get a chiltons/haynes book and take a look at it or maybe someone else thats done it can chime in.I really dont think its a major operation.
Well i have no idea what to do now......I tried going to work this morining and usually the car runs fine until it get s hot...well forget that idea...i made it about 3 blocks..they car would idle but would not take gas...when i tried to get it to go it Backfired so bad thru the exhaust sounded like gun shots....the car stalled would start tried to move backfiring....finally got it back home which was 3 blocks away but barely..what can be going on with the CAR.....
I'm putting my chips on the Wires or fuel pump. I don't care if its new, I had a fuel pump poo out on me a few hundred miles after install. Granted mine was an 86GT so i had fuel injection, but the car would revv no problem, once under load it wouldn't rev past 5 grand. As the days went by i couldn't get over 4 grand, then 3, then 2.. She would idle fine and rev under no load, once i put a load on her, she would stumble, backfire and die. I think its your pump mang :shrug:
I dont know about that i have a big old fuel pressure gauge staring me in the face....lol and the pressure never drops off when the car is acting up..it has 5.5-6 psi at all times....i would agree with you if the pump would go down to little or no fuel pressure but its not...I think its more electrically but what i dontknow...the plugs are new the wires arent that old cap and rotor arent that old replace the duraspark yesterday..only thing left is the Dizzt i guess....oh coil isnt that old either...
Nope at work had to have a friend pick me up the car would even go today the idle was ok started right up tried to drive it forget it...Bucking ...misses....stalling and huge huge back firing thru the exhaust....scared the hell out of me...barely made it 3 blocks i had to turn around and barely made it back to my house....i have no idea whats wrong with it......any one have any idea....:(
Im thinking timing issue without a doubt. you say it backfires through the exauhst? Mine did that when the timing was off.
Timing hasnt moved....i marked the Dist..way back when i got it...still ont hat mark...this problem started as a slight buck or stumble once in awhile not i cant even drive it so something got way worse...I thought it was the carb because it had a faulty casting for the step up springs...Replaced it woith a new carb that didnt help still runs the same....new dura spark module...stil runs the same ..new plugs...etc...Th eonly thing i think it could be is the Magnetic pick up in the dizzy but i thought they either work or dont work.,...Also i have no EGR valve spacer plate block off...I have a gasket....phenoilc spacer ...gasket..then carb...im wondering in that hole under the intake is effecting the air flow or air mixture...its stil the stock intake i have..i have no poluttion stuff anymore no air tubes no air pump eveything is gone....Im lost....the car ran ok after i took the EGR valve spacer plate off i took it off to put that phenolic spacer on due to the carb boiling over the EGR valve spacer plate was cast it held heat...so i took it off threw it away and that where on at now....:(
Looking over the pics:
the black wire on the electric choke, is that a ground wire? maybe with the phenolic spacer it's not getting a good ground and causing something funky once the engine gets warm.
have you checked you cap and rotor? verify the timing! even though you have the dizzy marked, mke sure something didn't jump
the white electrical/vacuum connector, try putting some caps on the vacuum connectors
just tryin to help
just tryin to help
Yes the black wire is the ground...I think its ok i had the air cleaner off when i put the new carb on and i forgot to hook up the power wire when i did it opened and had tension on the choke flap so i think its ok....The cap and rotor well they look ok i replaced them a few months ago...im going to replace them again just to make sure there ok...I do nt htink i have any Vac leaks i set the carb up with a vac gauge yesterday it was steady and hels close to 20 inches of vac at idle..give it gas went to 0 then came back up to 20 again....I spoke to the Shop that did all my exhaust work all he works on is Mustangs he said sounds like the Magnetic pick-up is shot...could that be...If so he said pickup a new/rebuilt dizzy....i thought when a mag pick-up went bad in went bad wouldnt start the car or wouldnt run at all...
Any updates?
Yeah he car runs like ****....lol...I found the fuel pump...pressure to be to hight bought a regulator checked the floats,threw it on adjusted seemed good...15-20minutes running like total ****...smae tign everyday...everynite...15-20 then it goes down the drain...Im going to try one more thing before i either run it into a wall...give up on iy and sell it....or bring it somewhere and hope they can find it....The last thing in doing is moving the coil of the intake and reloctaing it the fender....maybe just maybe its overheating after 15-20 mintues creating weak spark...So tomorrow when i come home im putting on a new cap and rotor new coil and coil wire and moving the coil way way away from any heat source...if it does it after that i give up!!!!!!!!!!!!!!!!!!!!!! And on top of it all i have a nice tick in the exhaust that i never had before im just hoping its a misfire from the igntion or something....
Anyone want to buy a cheap 85 GT
Dont give up,i would at least try a reman dizzy.If i wasnt working the next 10 days in a row i would even give you a hand but i cant right now.If you seriously are going to sell it tho ,p.m. me.But if you did sell it ,i can gaurantee youll regret it.
Thanks for the other...:nice: Im sure it will still be not running right in 10 days....LOL....Im going to try the re-locating the coil and new cap and rotor...see what happens last thing is a Dizzy which i ordered so at least i'll have it but im not putting it in myself...lol..i'll take it somwhere.....And i am serious if tis car doesnt run good soon its gone...I cant have this type of headache i need it to get back and forth to work..i already lost 3 days in the last 2 weeks because of it not running right....
