Need Help Please!
91stangy
116
Today I completed yet another valve adjustment to further quiet the rocker chatter (I have 1.6 Rockers on stud mount heads). When everything was said and done, we reattached the valve covers and intake, plugged all the wire connectors and vacuum lines back to their original positions. Went to start up the car and it reved real high, maybe about 3-4 grand and then went dead. It was only started for maybe about a 1/2 a second.
(Just incase - I did zero lash, turned the nut down a little passed 1/2 a turn. I then tightened the poly-lock. And for the record I used "EOIC" - Exhaust Open, Intake Close)
I then went around and tested each valve for compression and as I thought; it was all good 1 through 8.
Does anyone have any suggestions or something I can go check on to possibly fix this problem. This is not the first time I have done a valve adjustment, never had a problem yet, until now. So any suggestions is much appreciated... thank you.
I don't know why I didn't think of that. That was the problem, a corner of the gasket somehow got folded over during the installation. Thank you very much for the idea!
