Need help please!!!!!
  • Thread starter Thread starter nunly94gt
  • Start date Start date May 9, 2009
nunly94gt
1,595
Mobile, Al
May 9, 2009
  • May 9, 2009
Ok, I did the MAF conversion on my 88GT. I cant get it to idle for anything. Half the time it wont stay running, the other half I have to keep my foot on it above 2k to keep it running. When it drops below 1500 it immediately drops to 500 and lopes for a minute then dies off. It will not start sometimes, then it starts great. All my connections look good but its getting dark.
It even backfired a little from time to time. I need some help fast!!!! If it sounds like a problem from the wiring end, which part? I ran the FP relay wire and the 2 VSS wires also. The only thing wierd is that the previous owner took the O2 sensors off the car. Was never a problem except for a little rich before.
Anybody got a clue?????
I used the IST MAF wiring kit......a 70mm cobra MAF for 19lbers and stock intake tubes from a 92GT.
Jason
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 9, 2009
  • May 9, 2009
Dumping The computer Diagnostic codes on 86-95 Mustangs
Revised 24-Apr-2009 to add warning to turn off A/C and place transmission in Neutral and dumping Engine Running codes.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
strtrcr50
Previously from Dirty Jerzey exit 7a
May 9, 2009
  • May 9, 2009
Did you unhook the vaccuum line from the MAP sensor on the firewall and plug it? Oh, and I'd recommend o2 sensors.
ID89GT
1,659
18
49
Spokane Valley, WA
May 9, 2009
  • May 9, 2009
I second the O2 sensors. When I got my car it didn't have them, and I put them on and it runs so much better, and gas mileage is a lot better.
nunly94gt
1,595
Mobile, Al
May 10, 2009
  • May 10, 2009
I at first forgot the Vacuum line, but then went back and unhooked it. it made it alot smoother but still shutting down on me.
strtrcr50
May 10, 2009
  • May 10, 2009
Do you have any codes?
nunly94gt
1,595
Mobile, Al
May 10, 2009
  • May 10, 2009
I havent yet, I have the old "star" tester at work. Ill bring it home and hit it tomorrow. Im gonna recheck my wires, it sounds like its not reading something correct. I know the O2 can be a problem but have never seen one cause my type of problem.
nunly94gt
1,595
Mobile, Al
May 10, 2009
  • May 10, 2009
Ok got it whooped!!!!!!!!
Seems that the signal wire wasnt pushed all the way into the harness plug. I pulled it right out when wiggle testing the wires. So its beat and idling fine.
Seems to be missing a little bit, and running rich due to my lack of O2 sensors. but I will take care of that soon. Atleast its drivable now and ready for some mods!!!!
Thanks for everyones help on this.:SNSign:
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • dan50
  • Jul 18, 2026
dan50
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
