  • SN95 4.6L Mustang Tech
Need help quick. Relieving fuel pressure
  • Thread starter Thread starter Skidzz
  • Start date Start date May 27, 2007
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
May 27, 2007
  • May 27, 2007
I've narrowed my car problem down to the #3 injector. I'm ready to replace it but I'm having problems relieving the fuel pressure. My manual says to disconnect the inertia switch and then start the car and let it burn up the fuel that's in the system. The problem is that my car won't start with the switch disconnected. I've also tried disconnecting the switch while the car is running and it just immediately kills the engine. Why can't I get this to work? Is there a better way to relieve fuel pressure so I can disconnect the fuel rail and fix this thing?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 27, 2007
  • May 27, 2007
Do you have a schraeder valve on the front of you passenger side fuel rail? Its a valve just like a bicycle tire has.
When you are doing stuff like this you of course need a full face shield or at a minimum safety glasses...
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
May 27, 2007
  • May 27, 2007
There's a schraeder valve on the driver's side rail. I really didn't want to do it this way and risk getting fuel everywhere, but I guess I have no choice. Any tips for doing this without getting gas everywhere?
steve_stang2003
195
  • May 27, 2007
Skidzz said:
There's a schraeder valve on the driver's side rail. I really didn't want to do it this way and risk getting fuel everywhere, but I can I have no choice. Any tips for doing this without getting gas everywhere?
Put rags under it.
Cover whatever you are going to press it with in rags.
WEAR SAFTEY GLASSES or a face shield and some gloves.
At the very least, look away when you press it.
Open the gas cap first as it relieves some of the pressure.
FWIW it only sprays for a second or two.
DTNODYA
831
  • May 27, 2007
+1 for goggles ...
Hold a rag over it ....
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
May 27, 2007
  • May 27, 2007
Ok. I replaced the injector. The car no longer bucks at 2000 RPM's, but there is still a significant lack of power above 3000 RMP's.
Here's the strange thing: When I removed the gas cap and tried to drain the schraeder valve, there was already no pressure. I had just turned the car off and was using a fan to cool it down, and the car runs, so there is enough pressure for the car to run. But again, no gas came out of the valve, and when I popped off the fuel rail it was the same thing; no pressure. I know that the injector needed replaced because of the white powdery substance on the #3 spark plug.
I have been driving the car on a bad injector for over a week since I changed the plugs. Should I change the #3 plug again?
Also, advance gave me an injector that looks different than the others. The old ones are orange. This one is black. The part # is 800-1060N. There's a piece of paper that came with the injector that says there are different styles of injectors for this car, but they all work the same. It fit just fine when I put it in.
This wouldn't explain the lack of fuel pressure though. Do you guys think I'll need to replace the fuel filter? Fuel pump? What the hell is wrong with my car? It's really pissing me off...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 27, 2007
  • May 27, 2007
Did you reset the PCM cause you should...
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
May 27, 2007
  • May 27, 2007
I just replaced the fuel filter, and now there is good pressure. I'm going to take it out for a drive and if it's still acting up, I'll reset the PCM. I'll let you guys know...
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
May 28, 2007
  • May 28, 2007
Ok, I've changed the plugs, the injector, and the fuel filter. It's still lacking major power above 3000 RMP's. I'm running out of things to do. I'm going to unplug the battery tonight and reconnect it in the morning. If that doesn't do the job, I don't know what else to do. I guess I'll have no choice but to take it to the dealership...
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
