- Aug 18, 2007
- 16
- 0
- 0
Alright...here is my list let me know if I should do anything different:
Here are the irems I already have:
Trick flow track heat intake-upper and lower
70mm Holley
70mm Spacer
Granatelli Mass air
BBK CAI
24lb injectors
Long tubes
Spec stage 3 clutch
strange adj. Shocks
Granatelli upper and lower control arms
strange adj. struts
NX wet kit
3:55 gear
Stock bottom end 5.0 w/ NX wet kit 150 shot
Some of the above items are on the car some still in boxes
Here is what im considering let me know of any info you might have or if you have anything similar
AFR 165cc Competition Port #1604
Anferson ford motorsport N-41 Cam
Scorpian roller rockers
3:73 Gear
Nitrous progressive controller
Moroso drag springs
Let me know if anyone has any suggestions or experience w/ something close to what I'm planning. AFR says my combo will work together and to expect 350-370 horsepower. Im planning on purchasing soon so I need some input on any of your experience or tech insight. Thanks Guys
70mm Holley
70mm Spacer
Granatelli Mass air
BBK CAI
24lb injectors
Long tubes
Spec stage 3 clutch
strange adj. Shocks
strange adj. struts
NX wet kit
3:55 gear
3:73 Gear
Moroso drag springs
