need help removing intake
  • Thread starter Thread starter 68GEETEE
  • Start date Start date Jan 8, 2004
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jan 8, 2004
  • Jan 8, 2004
I plan to remove the intake manifold and replace the leaking gasket on my '68 302 this coming weekend. I need to know what to do first, do I drain the coolant? I have never done this before but letting someone work on it besides me is not an option. ANy help, instructions, tips, do's, dont's would be appreciated.
HistoricMustang
2,359
Confederate States of America
Jan 8, 2004
  • Jan 8, 2004
You can do it.
Yes, drain the coolant. Do not force anything and take your time the "first" time. Use silicone to seal front and rear instead of the goofy gaskets they give you in the kit. Clean everything up and when you go to re-assemble use quality intake gaskets like Fel-Pro and put a small amount of sealant (very small) around the intake ports and make yourself a set of studs to guide the intake into place (I cut the heads off of some fasteners). Otherwise the gaskets will move.
Use a torque wrench and gradually move up to the specified torque. I believe it is 23 pounds. Start at 10, then go to 18 and then to 23 using the sequence specified (start in the middle and work out). If you just torque to 23 you might think it is right but it will be wrong.
You can do all of this without removing the distributor.
Good Luck,
HistoricMustang
www.hsitoricmustang.com
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jan 8, 2004
  • Jan 8, 2004
Forgot to mention I have an aluminum intake. Is the torque specs for the bolts still 23lbs or is it less?
D
D.Hearne
11,730
south louisiana
Jan 8, 2004
  • Jan 8, 2004
Make sure after you're done to change your oil too, you will undoubtably spill some coolant into the lifter valley when you remove the intake. Once you torque it to 23 ft/lbs go back over the sequence 3-4 times at that spec. Unlike Historic, I always use the "goofy" end seals and only had one or two out of 40-50 leak or squeeze out. And I don't use any sealer around the intake ports any longer, only the coolant passages and the corners where the gaskets meet. A perfect set of guides studs for the intake are the 2 inch long factory carb studs. Use one at each corner intake bolt hole, then remove them when you have the intake in place and 4 other bolts started.
DarkBuddha
2,215
Seattle & Tampa
Jan 8, 2004
  • Jan 8, 2004
If you don't own one already, immediately go out and purchase a Haynes/Chilton manual for your car. These manuals pretty much explain the procedure for doing almost anything to your car.
SL 1993 R
287
California
Jan 8, 2004
  • Jan 8, 2004
if you use silicone for the front and rear of the intake, make sure you let them dry properly, so they have time to set up...
D
D.Hearne
11,730
south louisiana
Jan 8, 2004
  • Jan 8, 2004
One other "better" manual, in my opinion, is to get a "Motor Repair Manual" these are out of print, but you should be able to find one thru Barnes & Noble's website. I bought one two years ago to replace the first that I had that got misplaced. The one to get is for the years from 1964 to 1970. This book is a goldmine of info, not just on Fords, but all US makes for those years.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jan 8, 2004
  • Jan 8, 2004
If I am installing new gaskets, what purpose does 'sealer ' serve? Isnt that what the gaskets are supposed to do?
67GTA-FB429
777
Tri-Cities, Wa
Jan 8, 2004
  • Jan 8, 2004
The sealant (RTV) helps seal the point where the gaskets meet and leave a little space for leaks. It also ensures a full seal around your water jackets.
Get a Haynes/Chilton manual so that you will know the correct torque sequence, it is very important, especially with aluminum manifolds.
Take your time doing it. If you get confused, just step back and re-read the book. Gaskets are cheap and so is RTV, but engines are expensive.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jan 8, 2004
#10
  • Jan 8, 2004
  • #10
thanks for the replies, you guys know your stuff!
D
D.Hearne
11,730
south louisiana
Jan 8, 2004
#11
  • Jan 8, 2004
  • #11
You don't HAVE to use the factory torque sequence, all that's neccessary is to start with the middle bolts and work outward in a criss-cross fashion. I quit using the factory sequence long ago and have not had a failure in either head or intake gaskets failing cause the torque sequence wasn't observed.
67GTA-FB429
777
Tri-Cities, Wa
Jan 8, 2004
#12
  • Jan 8, 2004
  • #12
You are correct about not using the factory sequence. But for a first time application, it would be better than guessing.
67GTA-FB429
777
Tri-Cities, Wa
Jan 8, 2004
#13
  • Jan 8, 2004
  • #13
One other thing; if you use the sealer instead of the gaskets on the front and rear, make sure you put down a thick enough bead otherwise you will leak oil.
HistoricMustang
2,359
Jan 9, 2004
#14
  • Jan 9, 2004
  • #14
Ditto on not using the factory specs. You can always tighten them up a bit more. If you over tighten and compress gasket too much and then have to back off, you may have to start over.
Just do the sequence (starting in the middle) several times using a "small" torque wrench if possible, not the monster wrench you would use to torque down Head Bolts.
HistoricMustang
www.historicmustang.com
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 6:08 AM
DadLife0724
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
