need help, rockers will not tighten
Billy8380
68
just put on a new set on comp cam 986 srings and now my roller rockers chatter like crazy and when I pulled the valve cover back off and open valves are loose?? Need longer push rods?
I am running an tfs1 cam on stock pushrods, ran fine before I got the new springs in. Sorry if misleading valves aren't loose the rockers are loose on the valves that are open
spring specs if it helps. just grabbing for straws
Dual Valve Springs
Outer inside diameter: 1.070"
Inner inside diameter: .697"
Seat load: 132lbs @1.750''
Open load: 293lbs @1.250''
Coil bind: 1.150''
Rate: 322lbs/in
found out coil bind was the problem, heads need to be machined for the springs. Comp cams told me first round they were ok and then the 2nd technician said they wouldn't work
