Need Help, Swapping 89 to 90-93 Dash
ike34
156
12
Waterloo, IA
Im thinking about putting a newer dash into my 89, Ive been doing some looking to figure out what swaps and what has to be changed. Here is what Ive come up with so far.
HVAC Controls have to be swapped or the dash modified
Fuse box has to be moved or the dash modified
Lower dash panel on drivers side has to be swapped
I can use my 89 cluster and cluster surround
I can use my column sorrounds, and keep my 89 tilt column
Some say yes and no about the center console
If you have done the swap or know what swaps, your help would be appreciated
Yes, you can reuse your cluster, cluster surround, steering column and column trim. You will need to swap hvac controls.
You could mod center console to fit, but the color may not match
Also front shoulder belts mount about 1" lower than the 90-93 cars so you'll need to drill a hole thru the quarter plastics if you swap these
Sent from my iPhone 4S using Tapatalk
