Well, what exactly is your code? You said bank 1 and 2, that tells me passenger side and drivers side. There are 2 on each side, upstream (before the catalytic converters,) and downstream (after the converters.)
If your rears are ok and you're sure, switch the front ones around. Before you do that, check the whole thing for leaks, and if you find one and fix it, disco' the battery with the door open to reset the ECM and make sure it wasn't just a bad leak.
