OK, so I was installing the Eibach Pro-kit springs today along with Tokico HP (blues) shocks/struts. The rears went in no problem, but when I got to the front, I changed out the spring and went to put the new Tokico strut in and it seemed too short?? I used part number HB2036, which is what I was told was needed to be run with a lowered 2001 GT Mustang because it is 1" shorter than the stock height struts. Has anyone had this problem with this setup? Also note, I was trying to install MM Caster Camber plates as well, but even without the plates the strut seemed way too short. Was I stupid to buy the shorter shock when I could have just purchased the stock length Tokico's?
Please advise as I want to get back on the road! Thanks!
Edit: Part number is actually HB3026.
