Need Help Top End Knock
Shawno
hey guys My 1989 fox has developed a knock which seems to be coming from the top end. It only starts after it's been running for 10-15 min. I've checked the rockers and push rods every thing seems fine there. Just seems weird it only happens after it been running for awhile I figure if it's cam or crank it would happen as soon as it was started. Anyways any help or suggestions would be great
  • Sponsors(?)
mikestang63
SN Certified Technician
Aug 27, 2012
9,821
6,608
204
In the garage
top ends don't knock, they tap/tick
if you are hearing a knock then it is mist likely a rod or main bearing
Are you hearing a ticking or knock sound.
General karthief
Mod Dude
Aug 25, 2016
15,453
4,914
193
polk county florida
Try this, start the engine and let it idle, when the knock starts pull one plug wire at a time to see if the knock stops. Of course all that may tell you is you possibly have a rod bearing problem.
It could be that bad or as simple as a header gasket leaking, you could also take a long funnel and hold the big end to your ear and point the little end around header flange area and valve cover/lower intake area to isolate the tic/knock, sorry can't tell you anymore than that from a post.
Shawno
Ok so it seems the knock is coming from cylinder #5. It happens when I rev it up, once I let off it had a knock. It's fine while the rpm climbs but soon as I let off I can hear it for a second or so
