Need help, need to start my car!
Im very close to starting up my car, right now Im stuck trying to prime the oil system. Ive called a few shops and tried some local help but cannot figure out what my problem is.....
1. I have an oil filter relocation kit on the car
2. I have an oil prime tool, hooked it up to my 5.5v 1/2" drill and spun away (counter-clockwise)
3. After about 3 seconds I had oil pouring out of my oil filter relocation unit, so I screwed on the filter and now have oil pressure in this section of the block.
Now the problem:
I removed the stock oil pressure sending unit and put a straight npt fitting in its place with a T fitting on the end.
One side of the T fitting goes to my autometer gauge, and the other feeds a stainless braided line leading to my turbo.
When I spin this drill, for no matter how long, I cant seem to get oil up into this passage way.
I was told by one person that I cant just used a regular priming tool to get pressure here....because the distributor shaft has special grooves which carry oil up to this section of the block.....is this true?
Do I need to get an old distributor? grind the camshaft gear off to make it straight....and hook a drill on top to prime it?
FWIW, im not sure the year of the block in this car....its an 88gt but the block has been replaced. The block in there now has a flat tappet cam and flat hydraulic lifters
thanks for ANY help, this is driving me nuts, and I'm moving! and my cars stuck in the garage! it needs to move!!
Now the problem:
