  • 1994 - 1995 Specific Tech
NEED HELP WIHT PULLEYS
  • Thread starter Thread starter ejjmustang
  • Start date Start date Mar 17, 2004
E
ejjmustang
70
Pennsylvania
Mar 17, 2004
  • Mar 17, 2004
I can't get my alternator pulley off and my brother needs the gargage!!! When I try to untighten it just spins under my belt. Does anyone have any input from personal experience.
RIO5.0
6,892
N.H.
Mar 17, 2004
  • Mar 17, 2004
Those are a pain without air...Try using a mallet and take a couple quick wakcs at the wrench, sorta like trying to "jerk" it loose...short of that, just leave it on til you can get to a garage, its not all that much different from the stocker...same goes for putting it back on...really needs a couple whaps of an air gun to secure it...
E
ejjmustang
70
Pennsylvania
Mar 17, 2004
  • Mar 17, 2004
Thanks alot Do you think will hurt to run it with out the Water pump and crank be stock
red94fiveo
1,269
Wichita, KS
Mar 17, 2004
  • Mar 17, 2004
IMPACT WRENCH
Sorry, that probably doesn't help too much, but its the best and easiest way to take it off. Mine was off and on in a matter of minutes.
RIO5.0
6,892
N.H.
Mar 17, 2004
  • Mar 17, 2004
Run that by me again??? run without the w/pump pulley...
Joes95GT
3,132
Delaware
Mar 17, 2004
  • Mar 17, 2004
Running without the water pump is the second worst thing you can do to a motor. The first is not putting oil in it.
Joe
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Mar 17, 2004
  • Mar 17, 2004
Now youre starting to sound like Ernie (Seth 5.0 )
RC
Joes95GT
3,132
Delaware
Mar 17, 2004
  • Mar 17, 2004
RC
That's the best laugh I've had all day .
Joe
huskerpower02
770
KS
Mar 17, 2004
  • Mar 17, 2004
RC
we still love you ernie
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Mar 17, 2004
#10
  • Mar 17, 2004
  • #10
Hey leave Ernie alone.
Take the alternator off (disconnect the battery, 15MM lower bolt, 1/2 inch upper bolt, 10mm for the postive cable and two tabbed connectors) and bring it to your local auto parts store. Most have an impact gun and can remove it in seconds.
E
ejjmustang
70
Pennsylvania
Mar 17, 2004
#11
  • Mar 17, 2004
  • #11
If I were to run the car with the crank and the water pump from the undrvie set, but my alternator would still be stock size what will that do??
jmuva44
1,338
Richmond, VA
Mar 17, 2004
#12
  • Mar 17, 2004
  • #12
A lot of people run underdrive pulleys at the water pump and crank with the stock alternator pulley. It will be fine. Nothing will happen as a result of it. Just, theoretically, you wont gain as much with the stock pulley. Go ahead and keep it on till you can get to someone with an impact wrench. It only takes 5 seconds or so to get it off with the impact wrench.
94GTLaserRC
11,178
Mar 18, 2004
#13
  • Mar 18, 2004
  • #13
You may need a slightly smaller belt if you dont change the Alt pulley...but there is no problem using it.
I dont know how your cooling is, but with summer coming, you may not want an underdrive WPP.
CHRIS: in your sig: ...Blaupunkt reciever, white face guages....should be recEIver and gAUges!
RC
jmuva44
1,338
Richmond, VA
Mar 18, 2004
#14
  • Mar 18, 2004
  • #14
why?
deadly97snake
592
Manchester, NH
Mar 18, 2004
#15
  • Mar 18, 2004
  • #15
What I did was I put a socket wrench on the bold and I stuck a flathead screwdriver indise the alt. (where the fan looking thing inside is spinning, so I could stop it from turning) and I used a hollow steel pipe I had laying around and put the wrench inside the pipe(for leverage). I got it off in less than a minute.
Now I don't know if I could've hurt my alt., but I didn't when I did this and saved alot of time/effort.
-Mike
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Fog horn sound
  • brandon4v
  • Jun 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 23, 2026
squeak93
For Sale Vortech crank and blower pulleys
  • Dontknowchit
  • Sep 25, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 15, 2025
Dontknowchit
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
martroy
M
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
