NEED HELP WIHT PULLEYS
Those are a pain without air...Try using a mallet and take a couple quick wakcs at the wrench, sorta like trying to "jerk" it loose...short of that, just leave it on til you can get to a garage, its not all that much different from the stocker...same goes for putting it back on...really needs a couple whaps of an air gun to secure it...
Hey leave Ernie alone.
Take the alternator off (disconnect the battery, 15MM lower bolt, 1/2 inch upper bolt, 10mm for the postive cable and two tabbed connectors) and bring it to your local auto parts store. Most have an impact gun and can remove it in seconds.
A lot of people run underdrive pulleys at the water pump and crank with the stock alternator pulley. It will be fine. Nothing will happen as a result of it. Just, theoretically, you wont gain as much with the stock pulley. Go ahead and keep it on till you can get to someone with an impact wrench. It only takes 5 seconds or so to get it off with the impact wrench.
What I did was I put a socket wrench on the bold and I stuck a flathead screwdriver indise the alt. (where the fan looking thing inside is spinning, so I could stop it from turning) and I used a hollow steel pipe I had laying around and put the wrench inside the pipe(for leverage). I got it off in less than a minute.
Now I don't know if I could've hurt my alt., but I didn't when I did this and saved alot of time/effort.
-Mike
