need help wiring guages
are you refering to the wiring for the lights?? i would use the headlight wire. it should be a bigger red wire on the headlight plug. there will be 6 wires going in, tap into the big red one. on my car that was the wire for the headlights and went 12v when the headlight switch was pressed.
I'd use the brown wire (parking lights - that's when the rest of your instrment lights come on). You can also tap into the dimmer circuit so your gauges are dimmed with the rheostat. Fuse 13 or the dimmer or any existing dimmer light can be tapped into.
I would tap into the ignition wire under the column that's hot during crank and running but most folks pick a switched 12 volt donor circuit and call it good.
Good luck.
i tried the parking lights wire and it was only putting out 7-9V and the guages lit up dimmer than with a 12v source.
Are you sure you were not in the dimmer circuit? When you put a test light to it, the test light dims as the dimmer is run down (and a DMM shows diminished voltage).
Otherwise, there's an issue with the parking light portion of your lighting circuit that you might want to fix.
Good luck.
that's what I was looking for, I tried the dimmer and it didnt look that good, the brown wire worked perfectly. Thanks Guys!
