Need help with 302 swap
So I had a 95 Mustang V6 the V6 motor blew up and I’m swapping it for an 85 Thunderbird 302 with the AOD. I’m needing help finding the TV cable what shift cables will work the carburetor bracket I’m using an Edelbrock 1407 and for the life of me, I can’t find the carb side brackets the TV cable or what shift cable I need to use and I’m needing to do it for as cheap as possible because I’m 19 and I have no money and this is the only car I have. Can someone please help me
Don't take this the wrong way, being a young enthusiast please take some advice from an 'old man'.
I would say to find a cheap commuter blob (economy vehicle) to get back and forth to work. Building/repairing a 30 + year old car is time consuming and can get expensive, can't find a part, the subject of this post, how you gonna get to work? Just food for thought.
Now about the linkage issue, look at Lokar
https://lokar.com/ for cables and brackets for your setup.
Another vote here for getting another car while you work on your project. If you had a lot of experience in doing these kind of engine swaps, you would know that they're not done quickly. And you're trying to put in an engine and transmission that were not designed to fit in that car, so you're going to have to do a lot of research and experimentation in order to get all that to work. It's possible, but not necessarily easy or quick OR cheap.
I'm not trying to discourage you. Just trying to point out that this is a MUCH bigger and more expensive project than you think it's going to be.
Unless you have that 85 302 already, I would highly suggest that you get a 94-95 302 and AODE transmission. The swap will then be much easier, as you will be able to re-use many things from the V6. It would be even better if you can find a wrecked 94-95 GT rather than just an engine, because there are a lot of brackets and small parts that will be on the wrecked chassis that will be very hard to find otherwise.
I do have some experience with that kind if swap; I dropped a 95 Cobra engine and transmission into a 94 V6 body. This was my first engine swap project, and I had a wrecked Cobra to pull parts from, and it still took me months to get the project done. There were so many things I didn't know that I didn't know - new tools to buy, for one. In my case, I had a decent-paying job where money wasn't much of an issue. You don't have that luxury.
I already have the engine in the car. I have the engine running. I have the driveshaft hooked up to 85 302 literally have everything done. I just need to figure out the kickdown cable and the bracket for the carburetor to run the kickdown cable and to have my throttle connect to the carburetor. I already have everything else done. I got it done in five days.
Sorry to reply to myself, but I also had all the parts from the 85 Thunderbird and they were all pretty much the same motor mounts shift mounts driveshaft. All the sensors are the same for the transmission speedometer. I just need to hook up the cables to the carburetor and I need to know what cable would be used for the AOD transmission.
