  • 2005 - 2009 Specific Tech
Need help with clunking in front.
  • Thread starter Thread starter VibrantRedGT
  • Start date Start date Apr 13, 2009
1 of 2 Next Last
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Apr 13, 2009
  • Apr 13, 2009
I have an issue with the front end clunking over bumps. Mostly coming from the right side. Passengers can feel in their feet. Jacked the car up and checked some items over but found nothing. Took it to the dealer only to find out I was 6 days out of warranty and wanted blood just to look at it. My question is I've read a few threads on rattling but most were the vent. Has anyone come across front end clunk?
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Apr 13, 2009
  • Apr 13, 2009
does it sound like loose lumber bouncing around? if so, it is most likely the upper strut mounts.
Becca
Charlotte, NC
Apr 13, 2009
  • Apr 13, 2009
Definitely check the strut mount. I had that problem last year.
W
Wind-Farmer
268
Minnesota
Apr 13, 2009
  • Apr 13, 2009
get GT500 Mounts if you do....60 bucks online, dont get from dealer, they will charge 60 per side!!!!!
walter
1,054
Houston TX
Apr 13, 2009
  • Apr 13, 2009
+1 on the mounts having failed most likely and +1 on the GT500 replacements.
NastyStang113
1,567
Florida
Apr 13, 2009
  • Apr 13, 2009
Possibly strut mounts, usually only happens on 2005 MY cars though. It's possible ball joints are bad. How many miles are on the car?
VibrantRedGT
424
154
Boca Raton, Florida
Apr 14, 2009
  • Apr 14, 2009
Posted via Mobile Device
Just turned 22,000 miles. I traded my buddy for the car and he said it started at 9,000 miles.
I will check out the strut mounts since that is the concensus. Can someone post a link for the FR500 ones?
NastyStang113
1,567
Florida
Apr 14, 2009
  • Apr 14, 2009
Does the car have lowering springs? It's so hard to diagnose noises and clunks online. It's GT500 strut mounts, not the FR500 mounts. Any Ford dealer can get them for you or you can order them online at a OEM parts supplier.
VibrantRedGT
424
154
Boca Raton, Florida
Apr 14, 2009
  • Apr 14, 2009
Nope, car is stock other than mods in my sig. (which is pretty much nothing). All I know it's driving my nuts. Car is mint and never been wrecked or anything. It is mostly coming from the front passenger side. Feels like down low but its hard to tell really. Seems to be getting worse each day.
NastyStang113
1,567
Florida
Apr 14, 2009
#10
  • Apr 14, 2009
  • #10
Where are you in Florida?
VibrantRedGT
424
154
Boca Raton, Florida
Apr 14, 2009
#11
  • Apr 14, 2009
  • #11
Palm Beach.
NastyStang113
1,567
Florida
Apr 14, 2009
#12
  • Apr 14, 2009
  • #12
Damn, a little too far for me ...
hotcobra03
poteet,tx
Apr 15, 2009
#13
  • Apr 15, 2009
  • #13
clunk
as stupid as this sounds....#1 missed part....frame mount bushing for sway bar...it goes bad on the inside....seen so many spend so much ..and forget about a 2dollar rubber.
VibrantRedGT
424
154
Boca Raton, Florida
Apr 15, 2009
#14
  • Apr 15, 2009
  • #14
My garage is carpeted, air conditioned, 800 watt lighting, TV, surround sound and air tools.
VibrantRedGT
424
154
Boca Raton, Florida
Apr 15, 2009
#15
  • Apr 15, 2009
  • #15
Will check those as well.
Power4
200
Rochester, NY
Apr 16, 2009
#16
  • Apr 16, 2009
  • #16
Let us know what you find out. I have a similar noise that I've asked the dealer to check out several times but they didn't find anything. I'm betting it's the bushing and they just didn't check it.
blbrchnk
268
Bridgeport, WV
Apr 16, 2009
#17
  • Apr 16, 2009
  • #17
Can I come?
Steel
Modena , Italy
Apr 16, 2009
#18
  • Apr 16, 2009
  • #18
Same problem here with strut mounts - replaced with oem and then replaced AGAIN with steeda heavy duty - problem solved
Check also the A-arms for cracks on the stamped steel
And tighten the front swaybar
these last two are maybe a bit extreme , but don't underestimate a clunk .
Just my 02
Steel
VibrantRedGT
424
154
Boca Raton, Florida
Apr 16, 2009
#19
  • Apr 16, 2009
  • #19
blbrchnk said:
Can I come?
Sure. When I had the 94GT we did an engine swap party (347 Crate). Several Stagnetters showed up to work. I supplied all the beer and food. It was a regular thing after that. We all helped each other.
I checked around the font end yesterday. The sway bar end links are one long rod with bushings on each end. I can move that rod with my finger tip. I am use to my 94 where I changed every suspension part it had. Totally different set up on the 06. No caster/camber plate on this car either (well at least from the top strut tower). I have yet to look at the frame mount area where the front sway bar goes through.
mustangford289
957
Florida
May 22, 2009
#20
  • May 22, 2009
  • #20
Any update? What was it?
1 of 2 Next Last
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Electrical Need help identifying what these electrical items are (93 LX 5.0)
  • dan50
  • Apr 11, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
dan50
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
