Help anyone?? Wifes car wouldn't start yesterday in rain.It has had an intermitant misfire for a while so I replaced the coil pack and plugs/wires.Still missfireso out with the code reader,throws code 0352 bad ign primary circuit.So I test all conections check all wires clear back to the ecu.No grounds ,no shorts.So I do the primary output test in the manual to see if the test light flashes when the engine turns over."By the way cleaned all grounds ect.first" when you connect the light to red/blue wire for coil 3/4 light glows steady but dim even without engine cranking. My question is ,is the ecu gone or could there be another problem I am missing? Does anyone know of a fix for this? coil no 3/4 has no spark at all.Changed coil pak with another and still the same. Sorry for the long post but I have spent 2 days on this thing w/no luck.
