NEED HELP WITH CONVERSION
  • Thread starter Thread starter pvtdiaz
  • Start date Start date Jan 10, 2010
P
pvtdiaz
11
Los Angeles
Jan 10, 2010
  • Jan 10, 2010
i have a 1968 mustang with a 302cid engine and a c4 which is on its way out so i was wondering what do i need for t-5 manuel transmission conversion like where can i buy the parts to every part i need to convert it any help would be appreciated
68stang351
850
9
39
Savoy TX
Jan 10, 2010
  • Jan 10, 2010
There are a couple of ways to do it.
They way I did it is to use fox body Mustang clutch kit, fork, and bellhousing, and a California Pony Cars crossmember. The only other think I have to note is that I also used a clutch cable conversion from Ron Morris, but I also hear good things about Mustang Steve.
Another way is to buy the adaptor plate that lets you bolt the T5 to an older toploader bellhousing, which lets you keep the old bellhousing, clutch kit, fork, and linkage setup. You still need the crossmember.
Seems to me that if you already had a 3 or 4 speed in it that the second option would be better, but since you're basically starting from scratch I think you would be better off with going with the first option. It seemed easier to me too, so that's why I went that route. If you're going to have to buy everything anyway you might as well buy the late model stuff and a cable conversion kit.
Plus you can't shake a stick without hitting fox body parts so they are very easy to come by, which is handy if you're on a budget.
Obviously you'll also need a clutch pedal assembly.
Here's some links.
http://www.moderndriveline.com/Technical_Bits/classic_swaps.htm
http://www.moderndriveline.com/Technical_Bits/automatics.htm
http://www.sacramento-mustang.com/Newsletter/T5_Swap/t5_swap.shtml
http://www.mustangsplus.com/xcart/T-5-Transmission-Mounts/
That should get you started.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jan 10, 2010
  • Jan 10, 2010
You can quite easily, for a reasonable price, use the original clutch linkage. Everything you need is available new, and except for the pushrod hole in the firewall, completely bolt-on.
The clutch pedal is available new and used, and you can either replace the brake pedal, or trim it to "manual" size. The pedal bracket can stay in the car.
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
