Hissin. Brian emailed me back and said that he thinks the real issue is probe placement i.e. it may be pushed in too far thus spreading the fins apart so they aren't in good contact with the probe. So I just went out there, and repositioned it and started it up again. I "snuck" my wifes turkey thermometer out to the garage "I'll have to buy her a new one". I heald the tip of it on the fins by the probe, and didn't really get a reading, so I touched to the header, and the temp started really moving up fast. I let the reading go back down, and slid it down to touch the intake right up against the stock sending unit. (that's on the front drivers side of the intake I hope). The temp on the thermometer went up to about 135-140. Then I let it cool again, and slid it down onto the mechanical guage sending unit location on the back drivers side of the intake. Just like we were thinking ( well mostly you ), was right, the temp went up above 160, and was very slowly climbing from there. I went ahead and shut it down after that.
I think now it's very important that I take you lead and swap locations with the sending units. Please correct me if I'm wrong about the stock sender. It is on the drivers side at the front of the intake, a gold colored piece that has a screw if you will on the top that a barrel type connector slide over.
Did you say that you swapped yours? Did you have to cut the stock connector wire and lengthen it to reach the back, or was it possible to unwrap the electrical tape and pull it to the back?
What do you think, should I still buy a temp gun, and check it to be certain, or do you think the turkey thermometer is good enough?
Thanks again guy for your continued help.
