Need help with Door panel
  • Thread starter Thread starter Marengo
  • Start date Start date Aug 21, 2006
M
Marengo
  • Aug 21, 2006
Hi I just picked up a 98 V6 vert. Actually it is kind of a pre-wedding gift from my uncle. Everything is fine with the car except that the passenger side window doesnt work. He said that it might have been derailed or something. I want to pull the door panel off to check whats going on inside. Does anyone have a guide on how to remove the panel?
TIA
9
97sally6
129
  • Aug 21, 2006
its only held on by a couple of screws. different instructions if you have a mach sound system or not. there are 2 screws (i think its 2) where the speaker is/would go. use a flathead screwdriver to pop off the section by the door handle, but the handle stays on. underneath that there are 2 or 3 more screws. after removing them just lift up, it should come off with little effort.
'66 coupe
1,202
9
59
Lakeland, Fl.
Aug 22, 2006
  • Aug 22, 2006
Inside the the front door jamb there is a push-pin to pull out, that's first(look at the lower speaker grill and move into the crak of the door). Then remove the plate over the door handle(with the window and lock switches), be careful cause it breaks easily. Once it's off, unscrew the switch panels from the cover plate. Then you should see two screws under where the cover plate was, take those out. Next you have to push up on tabs through the bottom of the door panel, then the top should just come out next to the window.
Interior and Upholstery Inside door flex when window rolls up fully
  • beeduckworth
  • Sep 19, 2023
2K
Fox 5.0 Mustang Tech Sep 21, 2023
limp
C
Help with 2007 convertible / power door lock problems
  • cwood2314
  • May 12, 2023
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 12, 2023
cwood2314
C
Interior and Upholstery Restoring the Door Panels On Destiny the '86 GT
  • 86Fox_Destiny
  • Feb 15, 2021
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2021
rotorhead22
Door lock switch and power window issues
  • 02v6vert
  • Jul 3, 2020
1996 - 2004 SN95 Mustang -General/Talk- Jul 4, 2020
DaBard
D
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
